sil80drifter »
https://forums.nicoclub.com/sil80drifter-u622.html
Fri Nov 15, 2002 2:49 pm
replacing the chain/guides IS hard....it is a HUGE pain in the ***, and it is VERY time consuming. Having said that, I'll tell u that once u've done it, u can do it again anytime and the second time around u'll know what goes where. But I just replaced my guides and cam sprocket and chain this weekend, and somehow messed up on the timing, so now my car won't start. IF I did infact only mess up the distributor timing, then it will be a somewhat of an easy fix, but if I messed up on the chain links somewhere, I will have to rip the whole thign apart again, and that's...well again a huge pain, but this time aorund with more knowledge. Maybe I'm mechanically un-inclined, but some parts of takign off the cover, like unbolting/rebolting that one tiny screw behind the "squarish" thing behind the alternator bracket was one of the most annoying things I've ever done. Unboltign the coolant drain plug (something I thought was a pain in the *** before this weekend) seems like a joy ride now. Oh and order your chain/guides from Napa, but if you have a Napa stoe near you, go into the store and order it there that way u don't have to pay for shipping.
NAPA part numbers:
NTP94163S NAPA Timing Products Timing Kit: $ 114.00
NGAJV5004 NAPA Gaskets Timing Cover Gasket Set: $ 18.49
It will be a little cheaper to get from the store, but the tax will take care fo thatm sototal cost should be around $130 for botht eh kit and the gasket set. Kit includes chain, both sprokets, both guides and the tensioner.
Hope u have better timing luck than I did.
sil80
