another Tein superdrift question
le_ryan
Car: Mazda3
91 Nissan 240SX SR
so that i get this 100%
D = dampener - all the way to the right is soft and left is hard ?
G = spring adjustment - compressing the spring with the lock collars makes the ride harder/bouncy ?
E = ride height - right to lower, left to raise ?
C = shock mount
so if i want a nicer, tolorable ride, i have to extend the spring by lowering the spring perch ?
and then drop the height by rotating the whole coil over through the shock mount ?
how's my aim ?
onosqv
Car: '92 240sx Vert
zOMG NOOB!!!
hahahaha. For that many posts, you sure like to ask basic questions sometimes .
Anyway, direction for hard/soft & raise/lower should be obvious when you have the actual piece in hand (raise/lower depends on which way it is threaded - usually turning it to the right facing as the coilover as in the picture will lower the car; and H/S depends on the damper, but USUALLY it is right = harder).
SPL explains it best:http://www.splparts.com/doc/SPLCoilover/default.htm
The only good thing is at least you asked, I guess... there are a couple threads floating on this forum where members adjusted height purely by the spring compression, then complain that the coilover is super bouncy/harsh...
zOMG NOOB!!!
le_ryan
Car: Mazda3
91 Nissan 240SX SR
hey, so im a noob at coil overs, at least i can admit it, instead of screwing myself.I searched all day with no results, but this works, i think i figured it out after playing with it for about 2 hours.
