Socalgal »
https://forums.nicoclub.com/socalgal-u180316.html
Mon Apr 04, 2011 2:21 pm
So an update. Fans are working, compressor is cycling when the car is sitting at idle. But it runs hot while crusing. It's fine when parked sitting still but if I'm on the highway the temp will rise consistently until I turn I off at 95 ish degrees centigrade (read on my power fc). My car has pleanty of cooling fans, I've bleed the bejesus out of the coolent system, everything seems to be working as it should. Just too damn hot.
So this may be a dumb question but can the compressor be bad and still cool? Like could it be putting to much load on the engine? I've noticed that the clutch (center section) of the compressor spins easily when the car hasn't been run but if I park and mess with it after it's been running it's really really hard to turn. Not to mention very hot, but everything is in this state. Could someone with a properally working sr please try this and see if this is normal?
I'm aware of the triple pressure switch and that was taken care of by my shop that specializes In these cars when we did the ac the first time. It looks like they jumped 2 of the four wires. The compressor still cycled correctly and I was told it was correct so vie left it like that. I also replaced that canister because the system had been opened for so long. Moso thanks again.
