Once again, thank you to all those who completed the survey.
EvillE423 wrote:Done bro! What's this all about?
I'm working on a website where you can register your lottery numbers, then the program will match your numbers with the numbers that are drawn and send you the results. It's very convenient if you play the same numbers every time, because you only have to register your numbers once and then you get the results after every drawing.
I put together this little survey just to get an idea on what people think about this.
