another stupid question. sr20 t25/28 intake pipe (between maf and turbo) on ca?
kuruma
Will it fit. From what i have found (nothing!) i would say it will fit and practically any one will fit as long as the flange bolts up, but It doesnt hurt to ask before I buy.
thanks and forgive my ignorance (tryin to remedy it)
sdtouge
Car: 1990 240sx coupe
which turbo are you getting and i will try to help you, im switching to a t28 style turbo right now so i can help with what i know.lemme know t25 or t28 from sr.
NeedCAforS13
Car: CA swapped S13 coupe
are you talking about the metal inlet piece or the rubber piece?
from what I'm reading I think you're asking about the rubber piece. If so, you can use an SR one with no problems, just make sure you get the proper metal piece for whichever turbo you're using...
the t25 uses s13 SR metal inlet. the t28 uses s14/15 metal inlet. They're at different angles on the turbo itself.
Sean
kuruma
sdtouge: i have a s14 t28bb right now
NeedCAforS13: i need the metal piece that actually bolts onto the turbo. I was talkin with a cat on 240sxforums and he had one from an sr for sale. He took some pics that dont help me at all. Mabey someone on here can help me figure them out, but from your post it looks like im barkin up the wrong tree.
The next question would be where can i pick one up for mah t28.
sr20detmaybe
Car: 95 240sx
i got this pic in a group of pics from the same guy and hes selling the metal part that is attached to the filter. go to the classified section and post there. I also had to get the turbo inlet tube for the t28 bc mine was broken in an accident. u'll be able to find 1 bc a few people emailed me about them selling one. just make a topic bout it in hte classifieds and u should have no prob locating 1.
Nunook
I have a t25 turbo, and Im using the t28 metal piece. I had someone cut, rotate, and weld the piece so it has the correct angle.
i assume u can do the same thing. Use the t28 turbo, and the t25 metal piece. Use cut and re-weld. it was cast aluminum if u want to kno.
