Morgs »
https://forums.nicoclub.com/morgs-u67547.html
Thu Jun 07, 2007 6:05 pm
Ok heres the prob, when i get out to my car in the morning it doesnt want to start, it chugs and chugs, catches a little, and then dies, i try again, a little more chugging and it catchs a little more then dies, i try again with the peddle mashed and it finaly chugs chugs and catches. then it jumps to 2000 rpm and slowly settles.
Iv tried the iacv option, cleaned it reinstalled, no difference.
checked timing, its at 15* top dead center
i have spark
i have fuel pressure
Heres some more info, when its colder outside, it gets WAY worse, when its warm out the issue isnt as bad, it will start with some coaxing
after the cars been driven for a while if i turn it off and back on it starts right away.
so my question is how do i fix this? what im thinking right now is that it has something to do with the temp sensor that feeds the ecu, perhaps its junk and the ecu doesnt get what temp it is and doesnt adjust fuel and spark and whatever accordingly? does that make any sense? Im still learning the wrenching part so it may not make sense.
so IF that could be the case, i need an ecu temp sensor, i have heard that a KA one works for the sr. not sure if this is true or not but if someone could confirm this fact i would greatly appreciate it.
I also havnt touched the cas, as it was in another car and worked just fine i crashed the car, swapped it to a new chassis and now starting issues. so yeah, if someones got ideas PLEASE help, i would greatly appreciate it.
oh ya, and im runnin a stock sr, stock boost, stock sidemount, only iv done is a turbo timer, gauges, 3 inch exhause and 3 inch down pipe.
Any help i would greatly appreciate it!
Morgs
