240TweakerNewbee »
https://forums.nicoclub.com/240tweakernewbee-u27832.html
Mon May 01, 2006 9:56 am
I know this is redundant but I always keep the 3 simple things in mind:
Air - check for leaks, blocks, sensors, fuses, wiringFuel - leaks, blocks, fuses, wiringSpark - spark is spark, either its off or on, fuses, wiring
Check each system all the way through and youll find your problem. Also make use of or get yourself a voltage meter, processes in a motor can get really messed up from out of spec voltages and/or resistance.
