Another SR wiring question: o2 Sensor cut, is this the plug for it? (pics)
turblu
Ok guys... Im at the last of my Sr swap wiring details. I need to extend my o2 sensor but its cut at the o2 sensor (about a foot away from it). Im pretty sure this plug (pictured below)is the plug. I dont have the end that plugs into it for the o2 sensor. Should I cut the plug off and use quick-disconnect connectors? Also which wire connects to which plug?
Red: (brown Im assuming)Black: (black I'm assuming)White: (white Im assuming)
Am I correct here? Or am I totally wrong and this isnt even my o2 sensor wiring? The pics are down on frsports wiring diagram so this is making it harder for me to figure out.
turblu
bump
PhopsonNY
Car: 1989 Nissan 240SX
Checkout these links... they should answer all your questions
zerothread?id=128543http://forums.nicoc ... ?id=104643
good luck
