You might want to wait more than 2 hours from a post made near midnight before you jump on the "How come no one replied yet???" wagon.
http://www.nicoclub.com/FSM/misc/SR/s14_sr20det.pdf
S14 SR service manual. Go to page 294, and that should be the fuel pump wiring you're looking for.
Mating an S13 SR into an S14 chassis is a bit more difficult than the simple rewiring job on an S13 SR into an S13, but it's been done before. The S14's dash plug serves as the primary plug for the EFI harness, but on the S13, a lot of those wires go through the two plugs by the battery tray. You'll need to move a bunch of those back over to the dash side of the harness. My suggestion is to take the EC & EL section of the SR manual and the USDM 240SX manual, and make sure you mate up the wires from the SR harness to the S14 dash plug. Also, if you use the USDM S13 DOHC manual, most of those wires will match up with the S13 harness (aside from the way the ignition wiring is done, they're practically identical).
If it's too much for you to handle, you should consider getting a conversion harness.
