So I took a look at the plenum and noticed where there was a sizable blockage when the valves were open so out came the die grinder and I smoothed out all the passages. Then, since I had the grinder out I started smoothing the exterior to get rid of the casting flash.
Here it is "smooth":
Then decided that since the gasket will not be here until tomorrow I'll go ahead and "polish" it.
Here's the first go around:
Lots more to do but a pretty good way to kill a day!
I'm going to look into making some phenolic spacers to reduce heat soak on the upper intake. I think 1/2" would work well.
