another solution to the crappy torx cam cap bolts
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
blazin'240sx
Car: 93 s13 coupe se
I was tearing down a dodge 4.7 motor due to being overheated and figured i would see if anything was compatable with a vh45. So far i only found that the cam cap bolts will work, they're the same thread and only about 2 mm longer. Valve springs feel a bit stiffer but you would need to modify the spring seats and retainers.
frapjap
'07 Subaru Legacy
Very cool, thanks for the info!
Return to “VH45DE / VK45DE / VK56DE Forum”
