Klits562 wrote:You dont need a timing light to set your timing to 20*btdc there are markings on the crank pully idk which mark is 20* but if you do some more research i know its here somewere.
As for Hydro carbons thats unburnt crap iirc hydrocarbons are from low engine temp or maybe fromy our timing
as for NO, again iirc your EGR controls NOx get that line replaced and make sure your EGR is functional.
Yes a good cat can help reduce a majority of your gasses also
well thats good ill look for a write up or a how to on how to set it back to factory without the light im sure i can find it
i didnt realize that the EGR system performing improperly could have that much affect on the pollution, and little effect on the over all system of the car running. i did replace that line already and the light has not gone off so im going to have ot do a full check of it tommorrow and see if i can find any broken lines or kinked lines or a malfunctioning valve or solenoid in the EGR system and everything its connected too i think its just:
EGR valve, EGR solenoid (i think its tied into the carbon canister as well so checking that also) B.P.T valve as well and i think thats it right?
IACV-AAC would be a code 25
O2 would be a code 33
EGR temp (cali) would be a code 36
but when i was looking up codes online it said that an EGRC solenoid/valve would throw a 105? idono what this means...if a code 34 is the egr system and the code 105 is the egr solenoid/valve, that seems pretty controdicting to me...
