another s13 w/ starting problem.
ViciousCesar
Car: '90 420sx Hatch
so my car wouldn't start last night. i tried off and on for an hour and a half. eventually i gave up and push started it to get home. Today i took my starter out and took it to kragen to get it tested and they said it was still good. i put it back and the car and it started right up, my battery gave a good reading and i recently put a new interlock relay in. does anyone know what it could be?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Corrosion on the starter power cables or signal, or oily ground to block, Should have cleaned and wired brushed all surfaces.
The solenoid can also be starting its road to death
1KleenS13
I had an intermittant starting problem, turned out to be the relay under the hood near the battery (Big Blue one). I have a paper clip in there now and that works just fine . The car will start now without the clutch be pressed in. I havent gotten around to getting the relay and quite frankly dont care about it that much now. Someday i'll put one back in there.
ViciousCesar
1KleenS13 wrote:I had an intermittant starting problem, turned out to be the relay under the hood near the battery (Big Blue one). I have a paper clip in there now and that works just fine . The car will start now without the clutch be pressed in. I havent gotten around to getting the relay and quite frankly dont care about it that much now. Someday i'll put one back in there.
that's the interlock relay, i replaced mine less than a month ago. i thought would solve my problem.
OutToWinPAHC wrote:Corrosion on the starter power cables or signal, or oily ground to block, Should have cleaned and wired brushed all surfaces.
i do have a lot of oil leaked all over. maybe it's time for me to finally get around to resealing my oil pan.
thanks guys
