another rim/tire question
TurboKA37
I want to kno everyone's opinions on these wheels:http://www.pdm-racing.com/specials/specials.htmli really like the design and they seem like a pretty good weight for a 17x7 wheel. also, i need tires for these wheels. i was thinking either the yokohama AVS ES100 or the Kuhmo ECSTA supra 712. i need to kno what size will fit these wheels, tirerack.com suggests a 205/45 for 17x7 wheels but i was thinking a 215/40 if it would fit. all suggestions and opinions are welcome. thanks
Exar-Kun
Car: 2005 350Z
ir probably wont clear coilovers, and its a VOLK CE28N knock-ff...and its narrow, but otherwise its not a bad wheel. if you like the way it looks, and arent really worried about coilovers, etc it should be fine. run a 215-40-17 to keep gearing on a s13 close to stock(or a 215-45-17)-chetEs-100 are the way to go for budget tires man.
TurboKA37
they prolly wont clear coilovers? what about regular struts? (AGXs) thats what i have right now and i dont plan on buying real coilovers unless i somehow get alot of money sometime (still in highschool). im just looking for an attractive , fairly lightweight, good priced wheel. and this fit the description. i was thinking with a 42mm offset there wouldnt be any clearance problems but i could be wrong. do you have any other wheels that i might be interested in for under $200 a peice?
TurboKA37
hey exar, how much of a change did the nismo clutch line you have make? ive been thinking about getting one and have heard good things. also how do you like ur brake set up?
Exar-Kun
Car: 2005 350Z
the nismo clutch line helped with pedal feel, much like the SS brake lines did for my brakes. I just makes sensing clutch take-up a bit easier.
I love my brakes, although I did heat spot them recently, so I may be going to 300zx brakes once i wear these out. I heat spotted them durning repeated 100mph-0 braking during some "Agressive" driving...heh.-chet
TurboKA37
what about the wheels? do u have any suggestions on similar priced/sized wheels?
Exar-Kun
Car: 2005 350Z
My friend has those wheels on his sentra, not too bad for the money, if you like the look, and arent planning on running coilovers, those should be fine.-chet
96_240sxSE
those wheels look nice! although the fact that i think i see a machined lip may be the sole reason for my opinion. :D i love wheels with a nice machined lip.
and as for the tires...i'm guessing a 215-45-17 would be a lil more protection for your wheel investment IMO.
jun
TurboKA37
thanks for the input. im now looking at the 5zigen FN01R-C which i had origonally thought about getting but was driven away by cost but i think i may have found a nice deal.
TurboKA37
oh yea, what finish rim do you guys like best on a green/purple kinda changes color 240? hyper silver, bronze, or hyper black? i think i like the bronze the best but i think the hyper black will look the best on my car.
96_240sxSE
Quote »i like the bronze the best but i think the hyper black will look the best on my car.[/quote]
that would be my sentiments exactly. :)
TurboKA37
thanks for the help. im really having a hard time deciding on which rim and which finish to buy
96_240sxSE
i truly understand what you are going thru. like i was telling ben, who happened to go with the zigens that you are also looking at, i've been searching for months. the one and only thing i know with certainty is that i want a wheel with a machined lip. it defines the wheel a lil more IMO.
