Ligouri Rd wrote:The aiv is there to add air to the manfold to lean out the mixture at idle, removing that is probably what is making the mixture so rich. You are probably only running rich at idle so the rest of mixture should be fine. Unless you get your ecu reprogrammed to lean out the mixture at idle or put in a piggyback to do the same your gonna have to put the AIV back in.
Horrible misguided information. The AIV actually pulls air from the intake to direct air into the CATYLITIC converter to get it hot enough to operate under higher fuel dump loads. The AIV usually only does this during the first few minutes of start up. It has nothing to do with the fuel richness of the engine.Almost all the the Nissan programming for the KA ecu's run rich even when out of idle to prevent higher NOX levels caused from compressing O2 in the chamber (along with what ever else floats in the atmosphere)
Although if you meant by removing the AIV makes an incomplete vacuum withg the 2 vacuum lines found below the AIV (white, and Pink) than yes that is more than likely the problem. All those vacuum lines need to be connected
If infact the engine is running richer than usual these are the only parts that I know that would change the fuel cycle enough to have it run richer than it should.1.) TPS- throttle position sensor may not be alighned to the butterfly properlly.2.) O2 sensor will cause larger fuel dumping than usually if it is a bad sensor.3.)MAF sensor could be bad and throwing incorrect volt signals, that can throw the Air/fuel ratio off.4.) Check all your vacuum lines, you may not have correctly made a seal in all the vacuum lines (I'm talking about the AIV, and EGR that you disconnected buddy) .5.) Cam alignment if offset can have higher hydro carbons that go unvapoprized in the combustion process.6.) coolant temp sensorFor most of these problems the ecu normally doesn't throw codes, unless it is usually inoperative mechanical engine equipment. More than likely using a launch diagnostic you can fix this problem. Most mechanics that do smog and your basic oil changes should have this equipment....... It only takes 5 minutes to diagnose any of those problems that I mentioned....
Modified by Bigvinnie at 5:25 PM 1/24/2006
