msaskin wrote:If you take the lock tabs when they're over the nuts, fit an open ended wrench over it (i think a 15mm works) then hammer the hell out of it the lock tabs will form to the shape of the nut...wham! no more working loose
~matt
dj_lennon_franz wrote:that usually means you have a blown turbo gasget...u might wanna check on that
this happened to my SR and a friends SR...both times...blown turbo gasget...when i replaced my gasget i used locking nuts from a honda exhaust mani...but deffinatly check yer gasget (itll prolly come out in peices if thats the problem)
i've been sitting on my arse waiting for the damned gasket to get in. should be here tomorrow (i ordered it on friday)Me wrote: And not only did the nuts fall out, but it blew the flange gasket out, so now I have to order a new one.
how has the thread locker treated you? i just bought some liquid locktite, high temp and i'm about to use it since i recently replaced my gasket and the nuts came loose again..DriftS14 wrote:I used thread locker and got rid of the tabs.
When i recieved my motorset, the bolts where loose as well(and the lock tabs where locked in place ! ). I replaced the gasket and will be rechecking the bolts again tomorrow morning. How often do you guys go through this problem ?tenkawa_akito wrote:I have expressed my absolute hatred of lock tabs, and today I reaffirm my faith in that belief. Ever sicne I rebuilt my turbo, it started making a weird exhaust rattle under boost. I was exploring the exhaust system trying to find the leak when I noticed the turbo was loose against the exhaust manifold.
Turns out the lock tabs were loose just enough to allow the nuts to back off, so it was only held on by two nuts. And not only did the nuts fall out, but it blew the flange gasket out, so now I have to order a new one. I'm thinking some tack welds may be in order this time around.
Got any tips on making in a sinch? I took the turbo off while the engine was out of the car pretty easy. I've been procrastinating changing this gasket lately because my nuts backed out also.tenkawa_akito wrote:And taking the thing out is an sinch after you do it once. This time around I popped it right out.
