devil_child »
https://forums.nicoclub.com/devil-child-u58421.html
Fri Feb 22, 2008 6:57 pm
So, about a week ago out of nowhere I was boosting on the interstate, and when I dropped it down to 4th to pass, I started building boost and then at about 4400 it started to pop, sputter, and buck. Initially I thought it was because I was low on gas at a 1/4 tank, so I pulled off onto an exit and got gas from one of the places I usually do.
Started back up after filling up and it was acting normal again. Drove her the next day to work, and again same problem. So I started tearing into it.
So far:
on startup or first few minutes its fine, but then it starts to hesitate bad after a while liek 10 minutes of driving.
redid Idle speed for 750 and made sure timing was at 15*. Good.
Checked tps and idle switch good but tps is at .48 volts closed throttle???
AFRs are all good until I hit full boost. go from a 14.7-14.9 to a 12 until I hit full boost around 14psi and then it shoots over to lean and misfires.
Changed the fuel filter out and put a new fuel pressure gauge in. Fuel pressure is correct w and w/o vaccum.
Checked for leaks with a boost tester soap water and carb cleaner. Nothing.
replaced O2 sensor. (needed it).
Still need to check coilpack resistance and plugs. I am running a step colder ngk 6s with .028 gap. They are 2 months old.
Ran some seafoam through the fuel and the intake. (once again just maintenance)
tried some octane booster but it didn't help.
no bov leak. Pulling 18 inches at idle. Never pulled more than 18 FYI
Useful info: Internally stock rb20det. garret t3/t4. Rom tune with safc set up locally (no previous problems or recent changes). 450cc injectors. FMIC. Walbro pump 93 octane always, z32 maf.
I'm gonna try a different MAF tomorrow if I have time. Checking plugs and coil resistance too. I also think it could be the 450sbeing clogged. I had them cleaned, but iono plus they are loud. I can hear them from outiside of the car clicking but they have always been like that.
Any other ideas I'm missing? Thankyou in advanced guys.
