another questionable question
da40
Car: 1995 SE 240sx
ive looked everywhere guys how do u install a walbro fuel pump in a s14,ive read some for the s13 but they seam to be diffrent thanks guys
KATwo40
Car: 1993 240sx KA-T
It goes in the driver side front fender. I swear it.
J/K. Pretty sure it's either under a flap in the trunk floor or under the back seat.
MarkEmark
Car: fully-built '95 240sx KA-T
da40 wrote:ive looked everywhere guys how do u install a walbro fuel pump in a s14,ive read some for the s13 but they seam to be diffrent thanks guys
You can access it through the trunk or the back seat...but you need to remove a lot of crap to get to it. It's basically positioned in the area between the trunk and the main cabin of the car (where the rear seat back folds down), but you need to remove all the upholstery to get to it. And a word to the wise...i STRONGLY suggest getting your tank to empty before trying to do it, and do it in a well-ventilated area.
da40
Car: 1995 SE 240sx
hows the wiring like?cut the old harness off the old fuel pump and use the new harness the kit came with the new one? wire colors seam to be diffrent?
onosqv
Car: '92 240sx Vert
There's only a positive and a negative... black is negative.
You may have to resplice, and you may not, I don't recall what the walbro pump connection looks like - could be as simple as unscrewing the original terminals and putting them on the new pump or cutting the original wires and splicing in the new ones.
Just remember you gotta reach about 1-2 feet into the gas tank to get the fuel pump out on the s14.
Make sure the fuel sock faces the right direction and is the correct length also, otherwise you'll run into problems later.
da40
Car: 1995 SE 240sx
i put it in and wired it up but now the car wont turn over???hoses seam to be in the same way i took them off and i think i hear the pump buzzing when i turn the key to the on position but dosent turn over,could i have wired it wrong or switched hoses or something?
da40
Car: 1995 SE 240sx
finally found some direct info on the subject thanks for the help guys
98240
there is a write up in the 240sx/silvia forum
