I have found that it is much... much.. easier to do it from the top. You have to remove the airbox, which is fairly obvious to do. And then you have a "ton" of space to work with.elwesso wrote:6 quarts
Do it from the bottom.....
This is not good,because the MAF connector is very sensitive... You dont want to keep reconnecting it all the time, so its still best to go from the bottom... Thats how the FSM states.....PoorManQ45 wrote:I have found that it is much... much.. easier to do it from the top. You have to remove the airbox, which is fairly obvious to do. And then you have a "ton" of space to work with.
