Another Question on headlight switch
DAVIDMC100
Car: 1996 Nissan Sentra GXE
Okay, I have another question on my daughter's 1996 Sentra. (She's gonna kill me) Looks like the low beam headlights don't come on but when I push the stalk forward the high beams will come on. Is it probably the turn signal / headlight switch is what I need ( Nissan P/N 25540 ?) Can I just change that without the combination switch assy ?
DAVIDMC100
I'm still learning the Nissan terms but my main question is can I just remove the light switch without removing the steering wheel ?
ProudNissanFreak
Car: 2005 Imaginary WRX STi, 2003 Civic
Let me check the FSM
ProudNissanFreak
From what I'm seeing on the FSM, the steering wheel must be removed.
Instructions are here if you wish to do it yourself:
http://www.nicoclub.com/FSM/Sentra/1996/EL.pdf
Click on "Combination Switch" tab to the left and read on through "Headlamp."
Good luck!
DAVIDMC100
Good file. Actually on page EL-43 it says each seperate switch can be replaced without replacing the center base switch, but no one sells them seperately for this model year !! I may have to buy the whole switch to get the left side switch
DAVIDMC100
Anyone have access to a Nissan dealer parts list to see if they offer the turn signal / light switch seperately. My local dealer only found the combination switch. If I had the P/N I could go to the local delaer to get one.
ProudNissanFreak
I'll call today after class and ask
ProudNissanFreak
Parts guy said VIN number needed. Since I don't have it, here's the number I called:
1-407-472-0820
ABNRML4U
Car: Nissan B13
Take Care Bro, and Good Luck !!!!
