another question about vacuum lines :)
krazysob
I have a greddy FMIC supposedly for an S13. I know that the throttle body vacuum lines go to canister, BOV, and FPR. The wastegate is suppose to get its signal from a "nipple" on the hot pipe from the FMIC. But my question is i don't have a "nipple" on the hot pipe its an inch wide "nipple" is that suppose to go to something else or what? I was thinking maybe the PCV hose would connect to it? Its about the same size ruffly but i don't think the pressure would actually be good for it. Or is my thinking wrong? I thought that the PCV hose connect to the Air Intake? Thanks for any help?
KrazyS0b
Hijacker
Car: '92 240sx Convertible
'94 F-150
Isn't that for the recirculation valve?
Also, the PCV valve is on the other side of the motor and it connects into the intake manifold.
duffman1278
Car: 89 240sx Hatch, the wildcats!
That right there is for the stock BOV. Have it welded shut. Thats what I did. Or find some way to cap it off. Its not used
RPS13 DRIFTER
Car: S13 Hatch SR'D
i have a tee on my BOV signal line for my wastegate and it works perfectly
Deadrodent
Car: 1992 240sx hatchback
on the directions of the m-spec it shows a picture of it that nipple attaching to the stock bov...i'm putting the fmic on mine too at the moment and ran into this same deal
