89-240-TX »
https://forums.nicoclub.com/89-240-tx-u15462.html
Thu Apr 15, 2004 7:55 am
from my experience, if you are in-gear, with a manual transmission, and the clutch pedal is not depressed, and it surges like that, theres 2 things.
If Revs climb but you dont accelerate, then the clutch is slipping, is your foot on the gas? if so, then its your clutch, if not, its probably a combination of the slipping clutch, and one or more components in your air/fuel delivery system
If revs climb and you DO accelerate, then its probably one of your air/fuel delivery components.
if it is case #2, then you should have that looked at ASAP, cuz that is a serious safety risk, you car could accelerate you off the road, or into another car. bad bad.
