skinnay2 wrote:my driver side rear quarter window only goes half way up. i really dont think its the switch, it doesnt help if i push harder. do i need to replace the whole regulator like front s13 windows? how do i even take out the rear window regulator?
im pretty sure the track is just a little off.. it seems to go up at a bad angle till it gets jammed.
Your regulator should be fine. You have a broken plastic guide which is no longer available. It'll get worse as plastic guide worn out more. Most verts in junkyard also have broken guides too. You have to fabricate it...
