bobotech wrote:And whats the deal with that comment, brian, about the guide peices being in the sump. Geez. They know about that of course. Jesda got the most important part done, now he can worry about that later, at least the chains won't slip and grenade the motor.
Well, if you read enough of the prevoius posts about the chain guide problem, you will discover that missing pieces can be decimated sufficiently to clog the oil pump intake screen or even to be ingested into the oil pump, degrading its capacity and thus jeopardizing the whole (just repaired) engine. That is why the oil pump is always scrutinized for excessive wear. Oil pump chains are often replaced because of chain guide debris lodging between them and the sprockets or front of the block. There is a whole thread on how a failed guide piece caused a oil pump mounting bolt to back out.
Scott did a great job, but it is impossible to safely lift the engine (while supporting the transmission) without a lift and the other tools in a professional shop in order to remove the oil pan. As Q45tech says, one must account for all the pieces of the failed guides.
Everytime I see a G50 on the road, I am struck by what a classic car design it is. Often times, I even have to remember I am driving one. I want them all to stay on the road as long as possible.
Now that Jesda has conquered his fear of chain guide replacement, we as G50 owners must help him overcome his fear of failed chain guide parts retrieval.
__________________Brian1995 Q45 & Q45t & 2000 Q45
Discover the power of the button!
