HUSKE »
https://forums.nicoclub.com/huske-u296.html
Fri Feb 21, 2003 11:03 am
It could also be a timing chain bracket. Do a search for "timing chain retention bracket" or something similar. It seems almost everyone here has had that problem. It is an easy fix and makes a lot less noise.If there is a noise coming from the front of your valve cover, then that is probably it. If you can't find the fix, then email me, and I will tell you how to fix it.
