superDorifto wrote:no one is going to know the answer. Ive never seen a KA build with an electric pump - thought about it myself, but decided to stay passive.
Shut it!
chillmieste wrote:ok im setting up an electric vacuum pump into my pcv system. I was wondering what the ideal number of vacuum I should see. 15hg? Also at what number is too much vacuum
thanks
What type of electric pump are you using?
From all of my reading, you don't want to go over 18HG for fear of oiling issues. However, one solution is to install oil squirters, the KADE has these already
The HP gain from a vacuum pump comes from the ability to run low tension piston rings and still having a good seal. So unless you're building a well sealed motor and you're running low tension piston rings, you're not going to see much of a gain.
A regular smog pump will work for basic crankcase evacuation and be much cheaper than a system that will pull anywhere near 18HG of vac on the sump. A standard electric smog pump will pull about 3HG if the motor is sealed well. This is more than enough to keep seals from leaking and remove any blowby and pressure the sump might see otherwise.
