DrJuice164 »
https://forums.nicoclub.com/drjuice164-u29229.html
Tue Mar 03, 2009 5:53 am
Morning all, been a while since I have been on this board, but what better time to make a return.
So hears the deal, for the past month or so I have had cooling issues. It's a tad difficult to explain so please bear with me. On my ride to work in the morning I would have no issues with temp, but on the way in-between job sites, lunch, or home (anytime the car wasn’t fully cold) I would have overheating issues at slower RPMs (2k-3k). I found a temp solution being that when the revs were raised above 3k the temp would actually fall. Temp would fall to normal whenever on the highway. My theory was that I had a sticky thermostat and by building revs it would build pressure in the system and "unstuck" the thermostat.
After replacing the thermostat the previous weekend, I have had no success; in fact it’s actually worse. Same overheating and same fix but it just happens more often. SOOO I figure I have some air in the lines so I proceed to bleed the system, had the car on a slight incline (not very much though) had the bleeder screw out (wasn't a steady stream of coolant, but more or less lots of bubbles kind of frothy) and rad cap off letting it run with the heat on high. While doing this I check the hoses for temp, the top it mighty warm but the bottom is no where near as close. After going for a ride to put some heat into the motor, the lower hose is still no where near as warm as the upper hose.
Other notes, I do have hot air blowing inside the car. Oil has no coolant in it, and coolant is very clear (no oil). I also do not have a clutch fan; I have been using the AC fan for the past year or so with no ill effects. The motor is a NA dual cam KA with ~150k
So this is where I am stuck, my ideas are still air in the lines, defective thermostat, poor water pump or lastly a clogged radiator so basically everything.
If anyone has any ideas or needs any more info for a diagnosis, please let me know.
Thanks,
Bryan
