Hello, I'm pulling my hair out trying to figure out my issue.
I've had the thermostat replaced, and I don't think the head gaskets gone because there aren't any of the usual sign's.
We've tried bleeding the cooling system a number if times using the bleed screw on the rear coolant hose and following the methods online, but after I thought I cracked it tonight, the car ran perfectly for around 45 mins, then it got hot again.
Not sure what I'm doing wrong. I feel like there's still an air lock or I'm loosing lots of water somewhere I'll check the levels in a bit when it's cooled down.
Any advice would be amazing.
Thanks, Jake.
