DrifterXRPS13 »
https://forums.nicoclub.com/drifterxrps13-u10091.html
Wed Jun 01, 2005 1:32 am
i searched just to let ya know...here's my problem, i have an 89 s13, and it keeps overheating, kinda....it starts up fine and drives at normal temp for like 15 minutes...and then it'll get hotter, it'll rise all the way to H, then it'll sit there for a second (i have my heat on full blast at this point) and then it'll slowly go back down...this is after about 20 minutes after starting the car....then, it fluctuates depending on my rpms...if i take it up to 3000 and go a little faster than speed limited, it rises...if i stay below that rpm and stay at speed limit the needle stays at normal temp...the weird thing is that when i floor it and beat on it like crazy, it stays normal...well, i have a new water pump, and a new cap, the rad is full, and so is the reservoir....i noticed some coolant on the radiator from the upper rad hose so i replaced that yesterday, but it's still overheating...i tried the bleeding procedure to see if there was air in the system...nothing came out of the bleeder screw, i let it sit for like 10 minutes, and nothing....so i don't know what that means, unless i'm doing it wrong...also, i noticed that when i was changing my upper rad hose, the radiator itself is missing like 4 rows of fins on the backside, i only saw it because i was in a weird position trying to get the rad hose off...sorry i know its long but please help...
