another one of those, where does this go.
dvd
hey i'm wondering where do some of these hoses and pipes go.
the first one is on the block on the intake side. I assume its a water line but where does it go?
next are 2 openings for vacuum, where do they go?
and finally where does this go?
any pictures of the back of your ca with all the hoses attached would be GREATLY appreciated. Thanks.
dvd
for the 3rd pic, which valve cover does it go into. the intake or exhaust side?
biosehnsucht
first one is part of the heater and oil cooler arrangement, if it was for oil cooler it would have two outlets there, one it only goes to heater.
see here. the part labelled 14020H (MT) is what you have there and goes to the heater (at least looks like you have the non oil cooler variant), in the box top right it shows the oil cooler variant. Note it mentions which sections the connections lead to, if you put those #'s (213 or 278 for example) at the top of hte page you can go directly to those sections. Note that right now only the JDM diagrams are there so you'll note the heater piping goes to the wrong side.
second is indeed FUEL
third goes to exhaust valve cover. if you look at the exh side valve cover directly above there is a connection pointing down.
silvia_ca18det
Car: 350whp ca18det drift silvia
biosehnsucht wrote:third goes to exhaust valve cover. if you look at the exh side valve cover directly above there is a connection pointing down.
u mean intake
dvd
biosehnsucht wrote:see here. the part labelled 14020H (MT) is what you have there and goes to the heater (at least looks like you have the non oil cooler variant),
wow nice link, how come i didnt see that in the faq. I was wondering where did people get all the diagrams..
Yeah i have the non oilcooler variant. So i guess that would be for the heater.
biosehnsucht
my site
its quite incomplete (I have the diagrams mostly, but only JDM (RHD) and haven't completed adding in the parts info yet)
dvd
nice site you have there then.
sideways danny
Car: s13, CA18DET
1 heater 2 fuel in3 crank breather to inlet rocker cover
float_6969
#1 is for the heater.
#2 is fuel inlet and return. I don't remember which is which, but they are specific, so don't switch them.
#3 is the oil drain for the inlet side cam cover.
sideways danny
Car: s13, CA18DET
upper fuel line is in, lower is out
it's not an oil drain by the way, it's the crank case ventilation breather pipe
