elbles »
https://forums.nicoclub.com/elbles-u3033.html
Thu Apr 17, 2003 5:20 pm
Got another question about aftermarket oil pressure senders for everyone . . . regardless of thread size, what about the size of the senders themselves? I got a meter with an immemorable name from Levine Automotive, and the sending unit is so large, that once you add the adapter (BSPT->NPT), when installing the sender, it won't go in straight because it starts rubbing against the block (SOHC). I tried screwing the factory sender into the NPT side of the adapter, and it seemed to go just fine. Then, I went back to the car, and tried screwing the supposedly NPT sender into the supposedly BSPT block, and it seems to go fairly well, with little visible damage.
But, if this isn't the "best" way to do it, as I guess it isn't, what have you done to get an oversized sender to go in? Right angle adapter? Tubing based extension? I don't want to permenantly destroy the threads on my car, but from the comments above, it seems simple adapters are hard to find, I can't imagine what more complex ones would be like. Any and all suggestions would be helpful (I hope ;-)). Sorry for the long post . . .
