another o2 sensor for 96 i30
keje
Car: infiniti I30t
i have been checking online on many places about replacing 2 o2 sensors front and rear. I wanted to know if DENSO 2343098 will work for front and rear or will this require a different model. i'm trying to avoid the universal models.
maxhopper
Car: 02 Maxima SE 6spd
If you are going with an OEM sensor, the fronts are different than the rear.
Ryan Heo
Car: 1996 Infiniti I30
My 96' I30 was replaced all of the O2 sensors which is NTK 3 weeks ago. The front two sensors were found on ebay. Those are NTK $20 each one which don't have connect terminals but you can reconnect with oil terminal. Sure I did. Those are working good now. Otherwise the rear O2 sensor couldn't be found cheap one at ebay. However I found a little cheap one which was $46 also NTK. So all of the sensors cost $96 including shipping fee.Thanks.
keje
Car: infiniti I30t
do you happen to know off hand what those part numbers are
Ryan Heo
You can check it on http://www.ngk.com/default.asp. or call them.It is a easiest way to get a part number.
These are for my 96' I30 which is before 7/96. NGK OE identical O2 sensor 24525 FRONT LEFT $63.85 NGK OE identical O2 sensor 24525 FRONT RIGHT $63.85 NGK OE identical O2 sensor 24024 REAR $64.85
Thanks.
[Source: http://www.ngk.com/results_app.asp]
keje
Car: infiniti I30t
thanks a bunch
