leonelrr »
https://forums.nicoclub.com/leonelrr-u68907.html
Thu Aug 13, 2009 9:58 pm
The z32 hub is required if you are swapping the rear brakes to Z32. The S14 hubs don't have the necessary flange to keep the e-brake pin in place. The turbo model has some metal you need to grind off in order to fit properly. Avoid the turbo hubs if you can.
Since ur going to change the rear hubs only, you do not need to worry about abs housing...
BUt when ur doing the fronts as well keep that in mind.. I am running into that prblem right now.
