elwesso wrote:Another thought is maybe your guides are toast? Maybe you skipped a tooth causing a no compression situation and now you skipped another one and your getting valve/piston paddycake?
Hey Wes the guides have been done on this car. I got the chance finally today to take all the plugs out. DId that and tried to turn crank pulley and it turned. Tried starting the motor and it spewed the dumped oil out and started turning. I have left it @ that. What do you think should be the next move from my side?
Cylinders 1,3,5,2,6,8 all had oil on the bottom of the plugs and turned out they weren't even the right plugs. Major carbon buildup on top of the pistons as well. No valve/piston paddycake though. After further drying out of the spark plug holes, I am thinking new plugs as well as testing each individual coil for spark. Can that be done one cylinder at a time or gotta have everything connected??? Please help me out! Thanks
Update: Did a compression test on cylinders...Results:1= 2102= 2103= 2074= 2155= 110 (low)6= 2007= 55 (very low)8= 210
Modified by draivar at 7:16 PM 1/2/2008
