Another newbie
General discussion area for the U13-chassis Altima
tm_94altima
Car: 1994 Nissan Altima
Hello everyone,I am another newb. I joined this forum because a friend is a member here. I have had some bad expirences on other forums for Altimas. Few people know anything about performance and only talk about "What altezzas will fit my car?"
I drive a 1994 Altima. Mine is in poor shape, but I am planning to get another one in good shape and do a Bluebird SR20DET after I get enough info and money to buy all of the parts needed. If it is possible I would also like to convert from FWD to AWD.
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
Keep us posted on your new project. I would love to see how it goes. bud
tm_94altima
Nothing definite yet. I don't know how compatible everything is yet.
NISTECH
Its a complete power train swap , relocation of exhaust piping and I believe rear subframe with axels and hubs.
NISTECH
on an interesting note. The front cradle for a murano,L31altima,and A34 maxima are interchangable between cars. Can you say awd ,cvt, altima. I will say this though the floor pan at the beginning of the hump on the altima will need some slight modification to allow clearance for the rear drive shaft. As well as exhuast relocation [use murano exhaust] The rear subframes appear to be interchangable as well. [didnt measure the rear out, only measured out the front.]
tm_94altima
Well I was planning to do custom exhaust anyway so I don't consider that a problem. I was also under the impression that the fuel tank would need to be moved.
Return to “1st Generation Altima Sedan (1993-1997)”
