solaris22 »
https://forums.nicoclub.com/solaris22-u7801.html
Thu Aug 03, 2006 7:06 pm
I posted this on ka-t.org, but figured I'd throw it out there for you guys;
Newly built motor, the block/head are from an S13 the motor is in an S14. Intake manifold is from an S14. Enthalpy tuned ECU, AMS Adv rebuild kit (if that matters) along with a bunch of other stuff. Stabbed the dizzy about a 1,000 times, it's definitely not that. When I swapped dizzys it only took me two stabs to get it right on the host car so I've got the process down
Swapped distributors, same thing. Swapped spark plug wires, same thing. All the intercooler piping is on and all loose vacuum lines (that I know of) are blocked. At one point I got the car where it would regularly 'start' if I gave it gas on startup and it would idle really rough, like a harley or something. If at any time I take my foot off the gas it dies. This as done by putting it in some crazy degree of timing, I don't even want to guess where it was. Pressing the gas any more doesn't increase RPMs either, they just float around 800 with the lopey idle.
Ruled Out:ECUDistributorPlug wiresInjectorsMAF
Theory:Some sort of leak in the intake manifold area. Either the gaskets arn't doing their job or maybe the EGR blockoff plate or maybe some random vacuum line under the manifold didn't get blocked. Would a leak-down test show this?
Any other theroies are welcome, I really really want to drive this thing
