another leaky s13.....
lucky03602
Car: 96 d21 *work in progress*
01 xj Cherokee auto 4.0 4 1/2" lift 32x11.5x15 family dd
ok so heres the deal:im on my 2nd 90 240sx (first one had alot of body rot) and again a water leak in the trunki searched and found the "fixing leaky trunk" thread, read it and did what it said and still leaking
its not coming from the taillights, it looks like its coming from either the trunk seal think (black rubber seal thing along outside of whole trunk) or the rubber gromet that holds the rear defrost wiring (its a hatchback)
im gonna end up replacing both anyways but i was wondering if anyone has had this problem and how they solved it.
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
Its most likely coming from rusting under the spoiler. It is a very common problem on the 240sx hatchbacks. Water gets trapped under the spoiler and sits. And after a while it starts to rust. Just lift up your spoiler a little and you'll see what I'm talking about.
lucky03602
actually its coming from higher up on the car, reason i know is because the other morning on my way to work i was backing outta the driveway and i was turned around looking out the back window to back up and i noticed water coming out of the rear seatbelt plastic cover (the one on the roof/ next to rear side window) and i noticed the water dripping from the body panel hole into the plastic seatbelt cover. since water cant travel up an incline it leads me to believe its coming from the groumet or trunk sealon a second note also its only on my pass side, not on driver side at all so i know it has to be somewhere on the pass side incline or else the water would travel over to the driver side too
Ni2s4s0aSnX
You're just starting to confuse me. Just check your seals around the whole hatch, check to see if any are cracked or broken. Thats all I can thin to tell you.
lucky03602
well like i said im gonna replace the seal and the rear defog rubber bushing/groumet things anyways.
phuphyter
Car: 2002 Infinity G20
let us know how it goes. i think i have a similar problem, but its not raining right now so im not complaining
lucky03602
yea today im gonna take out the plastic interior on the pass side around the hatch area to see if i can get anymore clues to the problem but i believe im going to buy a new trunk seal and put some type of waterproof sealer in the rubber bushing thing that holds the wires for the rear defrost. when i do ill let you know]
GhostDriver
Car: 1991 Nissan 240SX RMS13
Same here....I thought it was my weather stripping because I have a slit on small part of it. It could be something else though. I love my S13!
