ANOTHER knock sensor plug Q
lostmenoggin
Car: 1989 Nissan 240sx ca18det swapped
already searched... my harness doesnt have the plug to connect to the knock sensor. does the one from Nissan come with the plug too, or is there a way i can hook it up without the plug? thanks..
davidricardo86
Car: 1992 Nissan 240SX SE
lostmenoggin wrote:already searched... my harness doesnt have the plug to connect to the knock sensor. does the one from Nissan come with the plug too, or is there a way i can hook it up without the plug? thanks..
Run a new wire from the knock sensor to the computer! Make sure to use shielded wire to prevent interference. Go to a junkyard for spare plugs if not part of a harness.
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
See if Nissan can sell you one still? Unless they sell the whole pulsar harness, but it couldn't hurt to try. I know my pulsar ca18de knock sensor is the same connector since it worked on both my motors
float_6969
Yea, your best bet would be to jank one from a junk yard.
