That's what I just thinking. Why would you try boosting if your motor is knocking?PyR0NiAk wrote:not sure about your knock, but as far as the fmic... Try T-Bolt clamps, although I wouldn't be trying to reach full boost with a knock...
If that is the case I will be blown away lol...I will stop and get some plugs tomorrowJasong wrote:Have you checked your spark plugs. I had a knock that I would have sworn was a rod. It turned out to be a bad spark plug.
Yeah thats what i was thinking so it really doesnt matter if i try to boost it or notJustin35ll wrote:if it is a knock it's not going to get anybetter.as for piping try getting new clamps.
ps. u stole positrons avy
Well the knock isnt at idle though its only through those before mentioned 2500-3500 rpms...and how would a bad knock sensor create an actual knock?Jasong wrote:Could also possibly be a bad knock sensor. I narrowed my bad plug down by unplugging coils one at a time. The bad plug didn't change the way it idled.
I am running 93 right nowPyR0NiAk wrote:try running a higher octane fuel....
Your wish is my commandPyR0NiAk wrote:nevermind then... i was kind of hoping you might have had a compression knock.. so many people call things KNOCKS that aren't really knocks... There is just a lack of words that describe sounds better... When people think knock, they think of the sound of bent rods and things of that nature, so without a sound clip, it's EXTREMELY hard for us to tell you what to do...
Did you even listen to the sound clip?? Dirty fuel lines aren't goingto cause the sound his engine is making...tvmendoza wrote:This is just an idea, but my friend's 3000gt had his fuel lines full of crap, therefore therefore the gas wouldnt burn as suppose to.Worth checking the lines
I changed the lines and fuel filter when the motor was swapped in...tvmendoza wrote:This is just an idea, but my friend's 3000gt had his fuel lines full of crap, therefore therefore the gas wouldnt burn as suppose to.Worth checking the lines
This is probably a stupid question but...by oiler do you mean oil pump?Jasong wrote:I agree with the valve train add oiler to that list also.
originally thats what i thought it was by the way the knock came and went but i just thought that the noise was a little to loud for it be that. So im thinking that im just going to order a new long block from jdm of miami and tear down this motorboro drift wrote:Sounds like a problem in your valvetrain to me. Possibly a collapsed lifter, or abnormally worn rocker arm.
A knock from the bottom end will not come and go. The noise you have is plenty loud to be a valvetrain related problem.A a l2 o N wrote:
Speaking of which has anyone dealt with them personally?
Touche sirboro drift wrote:A knock from the bottom end will not come and go. The noise you have is plenty loud to be a valvetrain related problem.
Yes i heard the motor before it was pulled (i pulled it)WizardBlack wrote:1. I can't hear the low quality vid very well (yes, I was in HD).2. Did you hear the engine RIGHT BEFORE it was removed? If not, it could have been ragged somehow before it was removed.3. Pull the valve cover and check everything in the valvetrain very carefully. Look for loose parts, but not fallen out, etc.4. Try using a screwdriver to hear for where the sound is coming from.
Please update me with what you diagnose!Asia989 wrote:i got the same prob with mine, valvetrain still looks minty fresh, draind the oil and it was jet black, well see thursday what the damage is on the bottom
