RSTi95 »
https://forums.nicoclub.com/rsti95-u233637.html
Tue Mar 25, 2014 8:59 pm
Hey guys Im new to this forum and relatively new to the Nissan Game in general. I have a 95 S14 that I just finished putting the motor together on and it wont start. It cranks and pops a bunch like it wants to fire but doesnt and then pops less and less the more it cranks. Unplug the fuel injectors and it will start and run for a second then die. Plug them back in and repeat the process. So I know its just flooding the cylinders but Im at a loss to why. Quick history:
Bought car in July of last year drove and ran fine, headgasket went, also decided to change the fuel pump, fuel filter, plugs, wires, distributor cap and rotor. Then in August it decided to start rod knocking. Fast foward 7 months and the motor is back together with new bearings, rings, gaskets and KA24E pistons because they were just laying around in another motor that probably would have never been used again.
So nothing that really affects the car starting was touched other than the mechanical timing, which I checked multiple times while it was going together. Distributor timing has been checked atleast 30 times, fuel injectors all showed 11.2-11.3 on an ohm check. Pulled the distributor and with the key on can manually spin the distributor and hear the fuel injectors click, fuel pump cycle, and even the spark plugs fire when pulled and grounded to the motor. Tried spark plugs gapped at .040, .030 and .025 no difference. Have tried unplugging the MAF, nothing. Grounds checked and even a couple added. PLugs pulled and dried multiple times. Fuel rail pulled and injectors sprayed into bottles, not spraying an excess amount of fuel and pulsing as they should.
Im at a loss here honestly. Im not quite sure what it could be. Tomorrow I am going to try replacing the coolant temp sensor as Ive seen in my searching that cause alot of issues but also heard that the car should start with it unplugged. Any ideas would be greatly appreciated Id like to start driving it again.
