Fergus »
https://forums.nicoclub.com/fergus-u27502.html
Wed May 04, 2005 4:04 am
I've read and taken a great deal of info from the other build ups I have followed.
For reasons such as school and $$ my build up will probably be extended through the end of the year, and upgrades for who knows how long.
But on to business. I got a '95 motorset that I'm gonna put in my '90 hatch. Since it has over 160k on it (the engine) I want to rebuild it now before I put it in.
As of now, the rebuild will consist of:
9:1 CP pistons
Cometic Metal HG
King Race Rod and Main Bearings
Block bored to 89.5mm
Block Acid dipped, cleaned and checked
File fit rings
New timing assembly, chains, tensioners, guides, and sprockets
New Water Pump
New Oil pump gears, and relief spring
Head cleaned and tested
Full rotating assemble balanced
This all comes at a price a little over my initial budget, but I am getting more than I planed on. I was thinking of ARP head and main studs, and possibly, as Ivan suggested, rod bolts as well. Is there any thing else I should get taken care of while the engine is apart?
Planning on going N/A while I save up for a turbo kit. After that, having initial horsepower under boost to be in the 200 range, to keep fuel upgrades to a minimum, with a Safc II to watch over things. Then get the parts needed for around 300 on a daily basis. Thats a ways down the road though.
Thanks in advance
