Another Ka is done
Florida240sx
My engine is now another to add too the list. Got a spun rod bearing..Sounds like it's on #3. After 2 weeks of working on it finially getting all the small things done...this happens. Don't know if happened before it got parked or if it happened today. I installed my 555 tomei injectors and #2 & #3 had bad orings. I started my car up and did a 5minute drive trying to tune it. Thinking it was just too much fuel and trying to take away on my SAFC. Checked injectors and rings where bad.Decided to drop in my sr 370's being no need for the 555's at the current time. Car wouldn't start due to gas being in the cylinder. Pulled plugs and got gas out.Changed oil.Car started right up. but now I got rod knock.....Trying to decide what to do. I might be able to get the bearings replaced for relatively cheap, but don't know if the rings on #2,3 are messed up due to the gas. I'm already buying another KA in about a month, but it was for the vert...Don't really need the engine built being my goal is only 300rwhp... Just trying to decide.I was just starting to gather pieces for my Vg swap....Was about to order coilovers, and some rims....
Craving4Boost
Car: 91 240sx fastback
how many frigging cars do you have
1WheelWonder
Car: 1991 Nissan 240sx
I vote rebuild.
erollinc
how much boost were you running? at the time
MS180SX
Car: 1989 Hatch- Crushed
1993 Hatch- Sold
2004 350z- wrecked
2005 STI- sold
2003 CBR 954RR- Sold
2005 Chevy Colorado- Sold
1972 Chevy Nova- Gas eater
geeus..im gonna start reading the dang sr forums....
But for real.. buy that 110K motor, throw it in there, and rebuild the old motor. Depending on how much the 110k motor is, you'll have you car back in a day or two, and you'll have an extra motor to rebuild to hold that 300 whp and anymore you could possibly want.
nissanfanatic
Car: 1992 Nissan 240sx SE
The stock engine will hold the 300whp.
I'd put money that boost didn't cause that rod knock.
Florida240sx
I'm going to replace the bearing and see how it is. I only hit boost of 5 psi at 3500rpms. Was trying to tune and had too much fuel. 555's. Didn't know the orings were crushed/tore. I drove 5miles at about 2500rpms.I never heard the rod knock while i was driving. Heard it once I got home and swapped injectors to 370cc's. Replacing the bearing. If it don't work, yanking motor and getting built.
nissanfanatic
Wait..
5min drive.. my car usually takes at least 5min of easy driving to even get it warmed up enough to beat on.... You didn't try to tune before the temp gauge at least reached operating temp did you?
GrilledCheese33
Car: 2008 Nissan Xterra
1972 Yamaha R5
2017 Sea Doo Spark Trixx
wow that sucks. There's been way to many ka-t's go kaboom lately, i think i might reconsider my ka-t plans and look towards a sr or rb swap instead. who knows. Good luck on whatever you do. I personnally would put in a temporary stock engine and rebuild yours then put your temp engine in teh vert when ur done with it.
GEO
Car: 95 240sx KA-T
^ nooo.. its idiotaic mistakes
GrilledCheese33
1972 Yamaha R5
GEO wrote:^ nooo.. its idiotaic mistakes
very very true. when i do my go faster project, im takin 2 weeks off from work and it will be done right and i will take my time to assure things don't happen
Florida240sx
I wasn't beating on it. Highest rpm it went up to was 3500rpm. When my idle A/F ratio is 9 and normal drivng is 10. I was just trying to set my cruising a/f ratio so my plugs wouldn't foul out.
