Replaced bad Intake gaskets and temp sensor, now the engine went from low and rough idle to a high idle and overheating. The fans aren't coming on and its getting hot. The engine idles between 1000 and 1500 rpm at idle, so I don't know what I missed or broke but something is wrong. I looked at all the vaccum hoses and the're all plugged in correctly. I installed a gasket between the throttle body and intake but I wouldn't think that would cause a problem. There is a small hose that connects to the upper intake right behind the pcv that got kinked but it looks like it goes to the heater core. I'm at a loss with this thing, can somebody help??
Fix: reset idle and replaced radiator cap. DONE!!
Modified by 01nissan at 11:21 AM 4/15/2009
