Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Tue May 23, 2006 3:38 am
I had the fuel rail flushed and a consult ran at the dealership on Lola. When I went to the Dyno, it seemed that the power was down a bit (maybe not). The car never seemed to have the power Layla did. The fuel mileage has always been less on her than Layla. The previous owner had several injectors replaced, if not all. It was a California car, but has spent the last 35,000 miles drinking Alabama gas.
Well, I was reading up on injectors, and was thinking that mis matched, or clogged injectors could be the cause of my perceived lack of power.
This leads to my questions:
1. Is there aconsult read out that will give me individual injector readings?2. Can I tell from the consult, if the ECU is having to compensate for dirty or failing injectors?3. Is there another test I could get the dealership to perform, to see if the injectors are all firing equally?4. If I replace the injectors, is there a preferred model or size?
Thanks for the information.
