O0ooAJoo0O »
https://forums.nicoclub.com/o0ooajoo0o-u576.html
Thu Nov 20, 2003 5:52 am
the click is probably a relay. look in the panel under the passenger side front wheel well. its right under the glove box. i think you have to take off the plastic cover. the ECU clicks sometimes, get someone to listen and then you manually make the car make the "click" most likely its the AC relay, but i doubt that is related to the idle problems.
it sounds like there is a relay in the ECU that cuts out the ac momentarily, when braking. ive heard of something similar to this before. i know mine used to drop rpms, but my ac is broken, so its always off.
also, you might want to check and see if the AC clutch is working correctly, look for a belt spinning, not sure which one, i havent done any AC work.
that rpms bobbing effect could also be temperature sensitive? maybe, have your temp sensor checked, or check if its even plugged in, mine shakes loose sometimes.
lastly, i would check all of your vacuum lines, even the little skinny ones. theres some on the intake box, theres some under the AIV, theres some on the throttle body, CHECK them all. idle problems are almost always a leaky/loose/unattached vacuum line.
hope that helps, keep me posted
