Another HP estimation!
sunnys14
Car: S14
black tophks tubular turbo manifolds14 turbogreddy intake manifoldblitz LM fmicz32 mafs15 480cc injectorsAVC-R boost controller @ 18 psimegan turbo extension3" downpipe+ 3" testpipe+ fujitsubo power getter exhaustjun chromoly flywheelexedy stage 2 clutchsafc-2
stock headgasket + stock head bolts
any guesses? no dynos in the area that i can find
fregisr
Car: 240sx 1990
wow you're pushing 18psi on 480 cc injectors. You're probably around 290. You should get a wide band to monitor your af
da40
Car: 1995 SE 240sx
yeah i agree get a wide band asap might be running lean somewhere,im running 18psi but i have 550cc injecs!Check that a/f asap
sunnys14
Car: S14
oh crap, i forgot to add that i have a PLX-m300 wideband... my bad.
deCksy
280ish... get some cams and let your motor breathe
yokota180sx
Car: 1997 Stagea RS4, r34 front
put it on a dyno instead of asking
da40
Car: 1995 SE 240sx
yokota180sx wrote:put it on a dyno instead of asking
dyno -jet probabaly the best way to answer ur question ,i know u said there isnt any dynos in ur area sounds like u need to take a road trip to me
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Run the car at the track. You can tell the power from your trap speed. Id guess your around 275-280whp.
sunnys14
Car: S14
was that post really necessary? if i could find one i would, why even post if youre not going to help the thread?
sunnys14
Car: S14
DrifterProdigy85 wrote:Run the car at the track. You can tell the power from your trap speed. Id guess your around 275-280whp.
track is closed for the year so i cant run. i was guessing around 280ish... hybridynamic's test car made 300whp @ 18 with stock manifolds, full exhaust, FMIC, z32 maf, 550cc + their custom tune. they have a dyno sheet also.
$350 for their stage 1 ROM tune for 550cc+z32+s15 t28.
u can find it here: http://shop.hybridynamics.com/...D=245
