Another Hard Starting Issue
antp
Car: 90 s13 hatch / 97 Celica
ok so here it is i have a 96 s14 with a bone stock ka. i have done all the tune up stuff. so the problem is the first start of the day is the bad one. the pump will prime and when i go to crank it over it turns and all that, but it takes long to start it and after like 15 - 20 sec it starts and runs fine. its only on the cold stat-up is the bad start. im just lost on why it could take so long to start up. Thanks for any inputs.
xekushnr
Car: '90 Nissan 240SX Hatch
Does it crank slowly? Or it will crank at normal speed and just wont start?
antp
it cranks like normal and it just takes a couple of tries to start it. so im thinking its something with my fuel system but the pump humms so i dont know. after acouple of tries it fires and idles great. so
remzon
Car: 93 240sx
hey i'm currently have the same problem, mine's a 93 hatch though. chances are it's the coolant temperature sensor, i'm buying one tonight along with plugs, wires, cap, rotor. i'll let you know how it goes.
antp
i did all that and still the same but keep me posted we can compare problems lol keep me posted.
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
make sure that the plug to your coolant temp sender for the fuel injection not to temp gauge, it is not all corroded nastier gnarly looking I have ran into quite a few of them that were absolutely green with corrosion and that was a problem
antp
so your sayin jusst check the plugs for corrosion. i got mixed up in your replie.
RR240SX
Coolant temp sensor. Notorious on Nissans.
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
wow I had the same problem with mine. right after a tune up it would be hard to start but only the first start or if I left it for a while. I had changed everything to include plugs, coil, coolant temp, cap and rotor, fpr, fuel filter, fuel pump, cleaned iac. and to no avail...
