viplife »
https://forums.nicoclub.com/viplife-u28815.html
Fri Oct 13, 2006 2:00 pm
Gents,
I need your help diagnosing my g50 (1994).
I spent a good amount of time searching for similar symptoms/problems that others may have experienced. I am also proud to say that I have used various posts/articles from NICO to get through many of the things I've done in the past! I post because I know there are many knowledgable techs on this forum.
Here is the history of the last couple weeks...
I did a ton of maintenance on the car when I bought it. I got it running in tip-top shape. I have driven the car without a problem for one year, and simply love it.
A newer Q45 (1998) popped up in the paper at an irresistable deal. I bought it. I have been driving that car since the day I got it. I parked the g50 in the garage and didn't start it for three weeks.
I decided to take the car out for a weekend drive...
I pull the car out of the garage, and it's fine. I park it in the driveway, and start to wash it. Dry it off, and go back in the house. I come out a few hours later and start the car. The idle is a little rough. I didn't think anything of it, and started down the street. Something wasn't right... It felt like a bad injector.
CEL comes on. I return home and run the codes. I end up with injector and maf malfunction. I disconect the maf plug and clean the terminals. I juggle the injector harness slightly, hoping it's a bad connection.
Clear codes and run it again. maf is ok. Injector code remains. I fire up the car hoping the injector code goes away. But the car still idles rough.
I used a bottle of fuel injector cleaner, hoping its a gummed injector. Drive around for a couple miles, and no improvement. Bought a fuel filter, but never changed it out.
I ohm all the injectors from the harness plug. All are well except one that isn't responding. I pull the plug and check connectivity through the harness. It's fine. I ohm the injector directly, and get nothing.
I buy a rewly referbished injector from deatsch, ohm it, then replace the defective one. Luckily it was in the front, so I didn't need to pull the plenum, just the plastic covers. I only removed the middle one, and left the two on the sides (especially the cas).
I try to fire the car up. Battery is dead. Strange. I have no aftermarket stereo, or anything electronic added to the car, except HID.
I get the battery charger out, and charge for an hour. Not enough to get 50 amps at 10amp charge, but should be enough to start it. It cranks, but the starter sounds like the battery still doesn't have enough cranking amps to turn the motor. I just sounds like CLICK... but not electronic, mechanical.
I charge the battery for 5 hours. Same thing, a single mechanical click.
Something is not right. I was inside the car thinking... When I ran the first CEL check I unplugged the harness. I glance over at the ecu and think, maybe I turned the knob counter-clockwise and forgot to turn it back. But it was ok. I turn it, and turn it back.
CEL ERROR CODE!!!!!!!!!!!!!!!!
What is it!?
11.
cas.
(no 0 or 9 degree signal, says the fsm)
wth?
Could it be because there isn't enough juice???
I get jumper cables and try to start it with the new Q. Same thing, a single mechanical click.
Something might be wrong... maybe more than the battery...
I know the g50 has the largest battery of maybe ALL infinitis out there, so I don't trust the battery that I bought only 1.5 years ago. I goto the store and buy a brand new battery. I drop it in, and Same thing, a single mechanical click.
Last night I went through and checked all the wires/connections/fuses. Everything seems to be sound.
I am stuck.
Any help, or suggestion is appreciated.
Single mechanical click...
and I noticed both (especially the negative) battery terminals get VERY HOT, and I only try starting it about 5 times (Turn key to ON, hear click, hold for a second, release).
Modified by viplife at 5:43 PM 10/13/2006
