Post by Aussie Q45a » https://forums.nicoclub.com/aussie-q45a-u28894.html Sun Jul 24, 2005 10:36 pm
Post by szh » https://forums.nicoclub.com/szh-u149.html Mon Jul 25, 2005 4:46 am
I think you are correct. As long as the pump is not loud. I.e., when the engine is on, the pump is imperceptible - without putting your ear on the back seat - you should be okay.Aussie Q45a wrote:When I turn the ignition on without starting the engine the pump makes "that" noise for 5>10 secs. until it builds up pressure then stops until I start the engine, then it maks "that" sound again while the engine is running. I have to put my head in the trunk to hear it. I'm hoping if it cuts out without the engine running it's OK, and that it's just pumping normaly whilr the engine is running
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
