szh »
https://forums.nicoclub.com/szh-u149.html
Mon Aug 31, 2015 9:55 pm
Not saying this is your issue ... but ...
Also, on the X models, all the tires and wheels need to be identical. Note that I did not say OEM, I said "identical". No staggering, nothing! But after market wheels can be perfectly okay. OTOH, if you do change the width and offset from the stock wheel values, make sure that the suspension axis extends to the same point on the ground to avoid unusual suspension travel arcs during its motion.
Basically, on an X model, if the front and rear axles rotate at different values (plus-1 kind of calculations do NOT work in this case, since the tire rolling diameters may be different for different wheel and tire combinations even if the calculated diameter is the same), this can put undue wear and stress on the Atesa AWD system ...
Z
